| | | Forums66 Topics128,036 Posts1,055,460 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 26 | About 10:00 PM last night I went to move my C50, which by the way was full of grain. I could not get it out of first gear. No neutral or anything just first. Anyone have any first suggestions before I start ripping the trany out? Trans has the high/low switch for rear.
Thanks, Richard | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Shift rail in the transmission is probably stuck. | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | I had a truck that did this. I had to pull the shifter and align the two shift plates that you will see looking down the hole. align the two square shift notches with a large screwdriver and you will be in neutral. You might have to rock the truck if driveline is loaded. | | |
