4 members (manymiles, Peggy M, Hanks custodian, 1 invisible), 105 guests, and 2 robots.
Topics128,151
Posts1,056,989
Members48,460
#890162 10/17/2012 10:58 PM
I just picked up another 47 today and is there a 2 ton truck? And if so how would I tell from a 1.5 ton? ohwell
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
3B Offline
Hy baldybenny, I believe the 1 1/2 tons have an eight sided screw in hub cap on the front axle, while the 2 tons have a bolted on cap on the front axle, hope that helps.
Thank you 3B!
Chevy, or GMC ? GMC trucks had ratings as high as 20 tons, while Chevy went no higher than 2 ton through 1955 2nd series.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Chevy, I should have said, Sorry...:)
Does the truck have a vehicle number tag on it?
If there is a model number on it, it should match the weights in 1948 .
I believe the 2 tons have a drum type parking brake mounted to the rear of the transmission versus the cables running to the two rear drums on a 1.5 ton.
Lots more pictures
I think that the 1.5 and 2.0 ton Chevrolet trucks did not have a propeller shaft parking brake until 1951.
47 model numbers and specs, 1.5T would be a 4000 series, 2T is a 6000 series and has hydrovac - I believe the frame will also be 'fishplated' between the cab and rear spring hangers on 2T
The code is QW and it has the bolt on front covers on the axle. there is no brake on the rear of trans, It does have the hydrovac,,, 6400= 2 ton? By what you guys have told me its a 2 ton! Thank you for all your help. Dan
