5 members (David Bush, NJC, Rusted Nut, GRNHydra, Hush), 52 guests, and 2 robots.
Topics128,060
Posts1,055,838
Members48,427
#889750 10/16/2012 9:34 AM
So for my 55 2nd, I was able to score an original Deluxe Heater control panel for the dash. I'm planning on using the heater and blower from my now-Organ Donor 56 3100 pickup. What I'm unclear about is if I need anything special in the way of a heater or will my 56 heater/blower adapt?? I've bought all of the cables, control arms, etc from the catalog but, quite frankly, I'm not sure how it all goes together. And I've not been able to find anything in the Assembly and Repair Manuals. Thanks guys.
Larry Bear
55.5 Chevy 3100 Panel
Larry Bear #889757 10/16/2012 10:02 AM
heater details are in Accessory manuals - see here and the preceding pic - if you don't have the deluxe heater [different versions shown in that album] then the deluxe heater control won't do much other than run the blower motor
Larry Bear #889861 10/16/2012 6:28 PM
Sir Searchalot
Sir Searchalot
But it will look nice on the dash! The delux has controls for temp, defrost, inside air, outside air and fan speed. The standard blows hot air on you.
Larry Bear #889984 10/17/2012 8:55 AM
Thank you Bill. I need to compare the pics to my heater - it sure looks like the one that came out of my PU... but I really can't imagine an old farmer out in Colorado having a Deluxe Heater having one - especially since the PU had a delete plate on the dash.
But you're right, at least it'll look purty! BTW Bill, thanks for your continual input, your pics and knowledge are a great resource
Larry
Larry Bear
