1 members (78buckshot), 112 guests, and 1 robot.
Topics128,136
Posts1,056,425
Members48,441
I'm looking for some help. I have 51 1/2 ton with fuel tank behind the seat. I can't find a
way to remove it. It has two straps but no way
to loosen or undo the straps to get the tank out. Its has about 4 gal of gas in it, that is rusty and dirty.
Thanks in advance for you help
Dave J.
...pic...
...pic...
...pic...
...pic...
There is a nut on the end of the straps.
As usual, DADS50 comes to the rescue with awesome picture references!
You'll need a closed end wrench to get to the nut.
DADS50 #889534 10/15/2012 12:53 PM
thanks for the pictures. I had not remove the seat frame so I can't see the the bolts. this should help alot. thanks much
Dave J.
