| | | Forums66 Topics128,284 Posts1,058,525 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88932 10/27/2004 2:07 PM | Joined: Oct 2004 Posts: 6 Junior Member | | Junior Member Joined: Oct 2004 Posts: 6 | I am rewiring my truck. The kit has great instructions for where the wires go, but I want to be sure I connect to the ammeter terminal correctly. Is the terminal closest to the negative side - for the negative wires and the terminal closest to the positive side for the positive wires? I makes sense to me. | | |
#88933 10/27/2004 5:25 PM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Leave enought slack in the wires so that you can switch them around. I hooked up the ammeter and turned on the headlamps. Sure enough, it moved toward "C" instead of "D". The diagram I had was wrong. I switched terminals and everything was good. You won't hurt the ammeter by wiring it backwards.
Gord 1954 1/2 ton 235 4 speed
