Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (UtahYork, 50Chevy3100), 197 guests, and 4 robots.
Topics128,284
Posts1,058,523
Members48,490
Junior Member
Junior Member
I am rewiring my truck. The kit has great instructions for where the wires go, but I want to be sure I connect to the ammeter terminal correctly. Is the terminal closest to the negative side - for the negative wires and the terminal closest to the positive side for the positive wires? I makes sense to me.
Leave enought slack in the wires so that you can switch them around. I hooked up the ammeter and turned on the headlamps. Sure enough, it moved toward "C" instead of "D". The diagram I had was wrong. I switched terminals and everything was good. You won't hurt the ammeter by wiring it backwards.
Gord
1954 1/2 ton 235 4 speed
