| | | Forums66 Topics128,078 Posts1,056,053 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 16 New Guy | | New Guy Joined: Oct 2012 Posts: 16 | HI, just got an old 40' Chevy running and was running well the few minutes I ran her as still getting new fuel tank sorted.
Anyway she is an Australian truck with rochester carby. I had fuel pump cleaned and pumping well. New fuel filter and just hooked up to a fuel can at present till tank sorted. The carby was pulled apart, cleaned and checked by my mech and was all gummy, but no carby kit freely available here so tried her as is. She ran good for a 7-8 minutes (whilst warming her up to do coolant flush)then just stopped. She started again and ran a while then she had a big flat spot if a reved a little and then some serious backfiring via carby so turned her off. This started as she warmed up. She seems to have a bit of a leak too as petrol under carby sometimes. Now on a side note I have had manifold off recently and was unable to source a new gasket so put her back with old one. Is it possible once heated there was more of an air gap somewhere? causing backfire? Or is it time to source a carby kit and clean her up? if so should I switch carbys to carter like some people here seem to recommend? or stick to rochester? I checked float and all good, but there was some crud in bottom of float so I siphoned it out and refueled. She started again today and ran OK for a short time before I got a small backfire and turned her off. She still has massive flat spot though and is a bit hard to start without a squirt of ethnol. I'll source a manifold gasket and change that too. j | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | It sounds like you need a carb rebuild .Maybe a lean pop,you give it a little gas and flat spot and popping though the carb. does it run ok after the flat spot? Or does it pop all the way up on the reving of the engine? http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | You might also check and see if your vacuum advance is working or not. You might have a hole in the diaphragm which will give you a vacuum leak as well as timing issues.
Kurt | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | I suppose it is possible for a carburetor malady to cause a backfire through the carburetor (I don't see how); and I have been working on carburetors since 1959 and have yet to see this.
Think how an engine works.
For a backfire through the carburetor to occur, a cylinder must fire while an intake valve is open, creating a path for the explosion to travel through the intake back to the carburetor.
This condition may be caused by:
(A) an intake valve which is sticking partially open or damaged (B) an intake valve opening at the wrong time (C) a cylinder firing at the wrong time
Not saying that the carburetor does not need rebuilding; just that other issues are causing the backfire and should be addressed first.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Check your timing and use the shop manual to set everything. I had mine set to the wrong mark and I was having similar issues. There's a triangle, a bb and a "TDC" (or something similar, its been a while since I did mine). | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Is it a backfire, or a cough? As stated, a backfire is an electrical issue. Loose wire, bad points, condenser, rotor, cap, coil, timing, etc. A cough up the carb is caused by the exhaust valve not opening, and the exhaust gas after combustion comes up the carb when the intake valve opens.
1939 Chevrolet Stake Truck
| | | | | Joined: Oct 2012 Posts: 16 New Guy | | New Guy Joined: Oct 2012 Posts: 16 | Thanks She ran fine for about 10 mins just idling very well as sat for years. The dizzy has good cap and has not been moved and even kinda stuck in place by grim lol but will check timing. My carby needs a kit regardless so will sort that and see. When i google search about backfiring almost all results talk about carby fueling issues (this would also explain flat spot) as backfiring very uncommon in modern efi cars etc so might start there and also get some new ignition bits anyway as truck very old. Replies may take a while as have to mail order parts where i live J | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have to say the comment that something mechanical needs to be wrong for a carb backfire has be baffled. It is very common for a backfire through the carb when the accelerator pump is not working causing a lean mixture. I have never thought about what causes this but it is not a mechanical problem, except in the carb.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2012 Posts: 16 New Guy | | New Guy Joined: Oct 2012 Posts: 16 | Yeah about 90% of the causes listed on just about everyhelp site i googled all pointed to carby or ignition as primary things to check? I found a carby kit in oz that i can buy so will find out in next few weeks once it arrives.
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Now on a side note I have had manifold off recently and was unable to source a new gasket so put her back with old one. Is it possible once heated there was more of an air gap somewhere? causing backfire? I had a backfire/pop through the carb. Problem was my intake manifold moved out of position just enough to cause the popping in the carb. PO did not use the intake sleeves to properly align the manifold. I installed sleeves, new gaskets and no more backfire/popping.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | sounds like a timing issue to me.
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Oct 2012 Posts: 16 New Guy | | New Guy Joined: Oct 2012 Posts: 16 | Now on a side note I have had manifold off recently and was unable to source a new gasket so put her back with old one. Is it possible once heated there was more of an air gap somewhere? causing backfire? I had a backfire/pop through the carb. Problem was my intake manifold moved out of position just enough to cause the popping in the carb. PO did not use the intake sleeves to properly align the manifold. I installed sleeves, new gaskets and no more backfire/popping. Yeah i read that gaskets could cause it and i think it is a likely issue as the old gasket was crap but had no new one at time (just ordering one today) It makes sense to as it only did it once warmed up after metal expanded. Either way truck is very old and carby leaks so planning on doing carby and gasket in about a week and will see. I checked points and very good cond, and bought new condensor too. J | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | A vacuum test may show low manifold vacuum- Sometimes. If so check for pluggage in the exhaust.Sounds like it was parked long enough for serious internal deterioration of the muffler, and the ever present "varments" love to build nests in the pipe--looks just like a mouse hole. Loosen the head pipe enough to get a sizable leak and see if the popping goes away. Pull the valve cover and lube the valve stems and other---.Sticky valves/guides can vary as the engine warms up causing the valves to not seat quickly--maybe even throw a pushrod out.
Bob Taylor
| | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | If an exhaust valve is not opening at all, the engine will regularly pop in the intake/carb and more violently as the engine throttle is opened. If the exhaust valve is not opening enough, as in a badly worn cam lobe, I've had v8's idle perfectly and run good at part throttle then when throttle is opened would regularly pop,pop,pop,through the carb. Observe the exhaust valve action if the valve cover is removed. Also you may isolate the offending cylinder by removing one plug wire at a time. Have seen an engine pop back from a leaking head gasket that burned away between 2 adjacent cylinders and didn't leak water.It sure didn't idle well though.
Bob Taylor
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Just fishing... I wonder if you have a stuck valve. Have you run it with the valve cover off? Any bent pushrods? It's common in old motors that have been awakened from long naps. Something about varnish in old gas gumming up the valve stems. Good luck with it.
Professional Novice
| | | | | Joined: Oct 2012 Posts: 16 New Guy | | New Guy Joined: Oct 2012 Posts: 16 | All sorted it was either carby or manifold gasket as replaced gasket (old one was missing a little bit) and had carby kit done...now runs great. | | |
