| | | Forums66 Topics128,023 Posts1,055,371 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88928 10/18/2002 1:33 AM | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | I have a '70 C10 and I need to know how to wire the reverse lights. They were disconnected by the p.o. and I don't know where the wires from the lights connect to. All help appreciated. | | |
#88929 10/18/2002 4:05 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | You should have a switch at the lower end of the steering column just on the topside.With the key in the on position(Wheels blocked of course) check the terminals while someone moves the shifter from park to reverse,neutral and back again.I do not remember which terminal it is as I wired in spot-lights through their own switch.I mounted the lights under the rear bumper.Just do not leave the lights on when there is a police vehicle folowing you
#88930 10/18/2002 11:30 AM | Joined: Apr 2000 Posts: 58 Member | | Member Joined: Apr 2000 Posts: 58 | Mechainiac, does this mean you had yours on with a bubble machine following you? | | |
#88931 10/19/2002 3:15 AM | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Thanks luke, I will check it out this weekend. | | |
