0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I have a 57 3100 without the keys. I plan to take the switch to a locksmith and have a key made, but I can't get it out. The retaining nut won't back out over the lock cylinder. I'm prepared to cut the nut with a Dremel if necessary, but I thought I'd seek less destructive alternatives first. If there's a way to forcibly remove the cylinder without damaging the switch, that's OK too. I'm willing to replace the cylinder and door locks with a matched set instead of hiring a locksmith.
Any suggestion from those who've gone before?
regards, Leon | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Leon, I have a set of master keys I'll let you borrow. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Cool. That option hadn't even occurred to me. Thanks. Can I get them at the Oct. Inliners mtg?
Leon | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | The try-out keys worked great. The 5th one let me get the cylinder out. Now I have to figure out what I want to do about the locks. Thanks a bunch, I'll bring them back at the Nov mtg.
