1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Are there any differences in the W-1 installed on the 216s and early 235s and how can I tell them apart,I am thinking about putting one on the 235 I have that I made to look like a 216 if I can find one from a early 235. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Don't know for sure, but I wanted to use a carter YF (on my 216,) a friend had, and it was from a 235. The spacing of the mounting holes was different, so it would not work. I sure an expert will be along to clarify....
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I was wondering if the bolt spacing was different on the early 235s like they are with the later ones. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Looks like I will need to take something to measure with when I go to the swapmeets,there are a few 41-6 big trucks at a local junkyard I need to look at but most have had the hoods open or fall off so I doubt any have any good carbs. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | The intake manifold for the 235 changed with the 1950 model. 1941~1949 manifolds for both the 216 and 235 accepted the Carter type W-1 carb. This link will help you identify the W-1 carbs: http://www.thecarburetorshop.com/CarterChevroletW1.htmFor the 235, best would be either a 483s or 574s. The 684s will function equally as well, but will be significantly more expensive. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
