6 members (Gdads51, 3B, 32Fordpuchoptop, Bill Hanlon, Otto Skorzeny, Joe H), 166 guests, and 2 robots.
Topics128,110
Posts1,056,246
Members48,437
#888909 10/12/2012 12:01 PM
Are there any differences in the W-1 installed on the 216s and early 235s and how can I tell them apart,I am thinking about putting one on the 235 I have that I made to look like a 216 if I can find one from a early 235.
Don't know for sure, but I wanted to use a carter YF (on my 216,) a friend had, and it was from a 235. The spacing of the mounting holes was different, so it would not work. I sure an expert will be along to clarify....
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
I was wondering if the bolt spacing was different on the early 235s like they are with the later ones.
yes
Looks like I will need to take something to measure with when I go to the swapmeets,there are a few 41-6 big trucks at a local junkyard I need to look at but most have had the hoods open or fall off so I doubt any have any good carbs.
Carburetion specialist
The intake manifold for the 235 changed with the 1950 model.
1941~1949 manifolds for both the 216 and 235 accepted the Carter type W-1 carb. This link will help you identify the W-1 carbs:
http://www.thecarburetorshop.com/CarterChevroletW1.htm
For the 235, best would be either a 483s or 574s. The 684s will function equally as well, but will be significantly more expensive.
Jon.
The Carburetor Shop
