8 members (WICruiser, Wheelie, Gdads51, Bill Hanlon, SWEET, TUTS 59, Phak1, 1955 1 Series),
90
Mod | | | Forums66 Topics128,187 Posts1,057,325 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I am sorry for this again i posted this about a week ago and it came up missing during the server switchover. I never was able to see the answers to what I asked.
I have a 1956 - 235 motor that was completely frozen. it was in a 3100 pick up. The head, and motor had so much crud and sledge in it so I was not sure if the block was good. its fate now is resting in a machine shop of ho tanking and inspection. I bought a 1955 - 235 motor as a back up. The 56 motor head had a casting #3836848 and the 55 motor had a head casting number #3701887. Does anyone know which is the better head? The 56 head was completely rused and gunked up but the 55 head was very clean.
I will rebuild one and just want the better head to use.
again sorry if this is a repost I just can not find the original question. thanks again
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | 848 head was the most used head for those years, it don't matter,either one will work for you,do the one with less work to do.,make sure that they have the water sending unit that you need, there's a big and small one, 848 has the big one, i don't know about the 887 head. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | i don't know about the 887 head. Me either but I do know the following combustion chamber sizes relative to casting number: 3836848= 79.1 cc 3835913= 86.2 cc 3836850= 86.2 cc 3703570= 95.5 cc
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Thank you Curt! That's good to know. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | The 848 seems to be the "preferred" head for most restorers. It's got a little more compression than the earlier heads and it really makes a 261 engine come alive when it's used on one of them. I don't think there's a port shape or breathing advantage, just a smaller combustion chamber. Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 3101887 is the code for a 1953 235 head. Does your head have the two bolt valve cover or the 4 screw valve cover?
As posted above, the 848 head provides better performance (higher compression).
| | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | The 3101887 has both. its being used as the 2 bolt because the person I bought the engine off of told me it was originally the 4 screw valve cover and he converted it. I still see the four holes where it meets the head however it is attached by the top two bolts. A little confusing huh. The motor the head sits on is from a 1955 235 motor, #3836233, 07250 59F55Y.thanks guys for all the help
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Any 4-screw head can be adapted to use the 2-bolt valve cover by simply substituting two studs at the proper location for the bolts that would normally attach the rocker shaft stands. Some people even go the the trouble to phony up a tall pushrod cover to make a 235 resemble a 216 when one is installed in an older truck. Jerry
| | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | My suggestion is to go to the 848 head. Then if you have the money send it to Mike Kirby at Sissell's, Automotive in West Covina and have him work the whole head over. When it gets back you won't believe what a difference a head properly ported and polished with larger valves will do. It is amazing! There are others who can do the same work with the same results but I use Sissell's when ever I'm doing inline head work. Their workmanship is tremendous! Normbc9 | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Ksissell's is Great to do the 230-292 heads, I have used his stuff in the past,big 292 stuff,lots of welding in those ports,and worked well with big roller cams. Great work from them! http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
