7 members (dt235sd, Bill Hanlon, bnauman, Ridgeback, Otto Skorzeny, 1955 1 Series, Chris's 46 / 515),
79
Mod | | | Forums66 Topics128,175 Posts1,057,115 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 11 New Guy | | New Guy Joined: Sep 2012 Posts: 11 | It's a pre 86 chev 350 just wondering if it will bolt up to the 4 spd Muncie? Or would I have to do an adapter plate? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You'll need the correct bellhousing, as the 6 cylinder bellhousing will not work with the V8. The bellhousing you'll nedd is be either the '55-'59 V8 or '63-'72 I6 or V8. You'll also need to either modify the corssmember or swap it out to allow for proper mounting, as the SM420 does not have a trans mount provision.
Bill Burmeister | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The bolt pattern a SM420 uses started in 1948 in trucks. It is the same bolt pattern passenger cars started using in 1955, if that helps.
See the USA in your vintage Chevrolet! My Blog | | |
