| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 12 New Guy | | New Guy Joined: Aug 2010 Posts: 12 | does anyone know if the OEM master cylinder contains an intergal residual pressure valve?
http://www.oreillyauto.com/site/c/detail/A1C0/1040000/01292.oap?year=1966&make=Chevrolet&model=C30%2BPickup%2BRWD&vi=1321951&ck=Search_01292_1321951_-1&pt=01292&ppt=C0066
apparently, the drums have been turned so many times now that normal shoes cannot reach the drum in one pump of the pedal. one pump = very little brakes second pump = locked wheels
o
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy john_brunson, if the master cylinder was designed for drum only brakes, then yes it should have a built in resisdual pressure valve, hope that helps. | | |
