1 members (Otto Skorzeny),
115
0
Mod | | | Forums66 Topics128,049 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | question.. outside of size of amps... whats the deal from gmc vs chevy generator... is there a differance.. and can either one be polarized just to work in a given truck... thanks Kat
I like fixing stuff.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy katrina, if the generators have the same frame (physical size) and pulley size, then yes they can be interchanged and polarized to work in either chassis, hope that helps. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Were the GMC's not originally positive ground and the Chev's negative? | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Were the GMC's not originally positive ground and the Chev's negative? Yes, but the only part that needs to have a dedicated polarity is the regulator. There's a difference in the arrangement of the cutout relay point material that causes rapid deterioration of the points if an incorrect-polarity regulator is used. The generator can be polarized to work either way without any concerns, other than maybe a part number mismatch. The actual generator is no different, regardless of polarity. Modern replacement regulators are often made to work with either polarity by changing a few internal parts. It makes it a lot simpler for parts stores not to have to stock both types. I'm not sure if a dual-polarity regulator is as efficient as a dedicated-polarity one, but they work well enough to keep the battery charged. Jerry
