4 members (Nick in Manitou, MickeyP, Jay R, MikeStone1953), 133 guests, and 4 robots.
Topics128,026
Posts1,055,405
Members48,422
#888390 10/10/2012 3:51 AM
This may be a dumb question, but do the 235's have any allowable side to side play of the distributer shaft within the housing? I'm just getting ready to do a tune up on the ignition system and noticed a lot of wear on a few of the distributer cap contacts. So naturally I check the shaft and it is pretty loose in there.
1953 1 ton panel
Probably be a good idea to pull it out and check things out. Not normal to wear on contacts in dist cap.
check the pin that attaches the drive gear
...video...
as you see mine was loose and played havoc trying to time. I found a replacement distributor on the shelf at my local NAPA.
Any side play in the upper bushing will allow the point gap to change, which alters the dwell and the timing. There should not be any noticeable side play at the area of the cam that operates the points. Roll the engine around until the points are fully open, then move the shaft around and watch the point gap change. Then go get yourself another distributor!
haha, thanks guys, that makes sense. I didn't think about it effecting the points. Guess I'll be looking at distributers.
1953 1 ton panel
