2 members (Uncles51, Shardean),
50
Mod | | | Forums66 Topics128,021 Posts1,055,356 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | This may be a dumb question, but do the 235's have any allowable side to side play of the distributer shaft within the housing? I'm just getting ready to do a tune up on the ignition system and noticed a lot of wear on a few of the distributer cap contacts. So naturally I check the shaft and it is pretty loose in there.
1953 1 ton panel
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Probably be a good idea to pull it out and check things out. Not normal to wear on contacts in dist cap. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | check the pin that attaches the drive gear ...video... as you see mine was loose and played havoc trying to time. I found a replacement distributor on the shelf at my local NAPA. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Any side play in the upper bushing will allow the point gap to change, which alters the dwell and the timing. There should not be any noticeable side play at the area of the cam that operates the points. Roll the engine around until the points are fully open, then move the shaft around and watch the point gap change. Then go get yourself another distributor! Jerry
| | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | haha, thanks guys, that makes sense. I didn't think about it effecting the points. Guess I'll be looking at distributers.
1953 1 ton panel
