3 members (Hotrod Lincoln, dt235sd, klhansen), 111 guests, and 2 robots.
Topics128,127
Posts1,056,679
Members48,452
#887772 10/08/2012 2:45 AM
Hi guys,
Upon reassembling my engine after replacing the head gasket, i somehow cracked the exhaust manifold in half. I looked in the LMC catalogue, they don't carry it. Neither does Rock Auto. Does anyone know where I can find a new one for it? Or am i subjected to scrounging wrecking yards (which seem very few and far between up here in Canada)
Truck is a 61 with the 235 six.
Do you have the cast part number for that exhaust manifold? I have a used one from same time frame only it's from a 261. I think it might fit though.
Drew
You are subjected to scrounging wrecking yards. I have never heard of any after market exhaust manifolds for the 235. Headers only. You should be able to find many of them used.
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
Hey Drew,
I believe the 261 had the same manifold. Mine has the casting number 3835587 on it.
Okay. I'll check to see what I may have and PM you later.
Drew
Adam, Sent a PM with 2 pics.
Drew
I just picked up an exhaust and intake manifold for my 235 through the local wrecker who is attached to one of those "across Canada" wreckers. It took 3 days to get it in. I'm in Saskatchewan.
Glen
Glen, so this was an auto wrecker with a canada wide search? Yeah I could try that...
Yes
PS: Make sure you have the exhaust and intake manifolds machined where the connect to the head, or they may crack again.
Hmm, ok...I DIDN'T do that the last time. Maybe why it cracked.
