3 members (j05h79, Phak1, Jay R),
73
Mod | | | Forums66 Topics128,154 Posts1,056,837 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | I h ave a 53 3100 with a 55 235. i had to get a new radiator a American eagle brand, from ebay, and today it came, the bottom tank is about a inch wider then the stock. it wont go down and gets caught up on the grill support bars inside the grill. what do i do. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If it is an inch wider you need to send it back. But I suspect you are talking about an inch thicker. In that case you may be able to shim it if you have fan clearance. | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | thicker . correct, sorry. i cant even get half way down. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I have the same radiator. While they are advertised to fit your 3100 they are not advertised as being the same dimensions as the thinner 6 cylinder stock radiator. Mine fits fine and needed only minor adjustment of the mounting holes to be bolted in. I am confused by your statement "gets caught up on the grill support bars". Your radiator is mounted on the engine side of the radiator support isn't it?
Drew
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | He has a later model 235. One solution to the water pump to radiator clearance problem is to move the radiator forward. Someone might have moved the radiator forward from the original location.
Grigg | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | drewP, the bottom tank hits the crossing rods that are welded in place, the radiator only had about .5 or .75 clearance to begin with, and was about 1.5 inches thick, the one the sent is about 2.75 thick and wont fit, and has trans cooler bungs that stick out even further grig, i know the 235 is a lil longer then the 216 but the clearance distance betweent the radiator and the fan was just a closer fit, my radiator wasent mover forward, and worked fine with the stock radiator. I think the one they sent might be for a v8 conversion, the one on the left looks like my broken rad, the one on the right is the one they sent http://i1095.photobucket.com/albums/i465/bigdrewvigil/al080071.jpg | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 |
the pics entirely dif hen the one the sent, and has a arch for a hand crank, (47/52 RIGHT? ONE OF THOSE WOULD HAVE WORKED)
THEY ALSO LISTED HEIGHT AND WIDTH, AND INLET SIZSES BUT NOT THICKNESS oops sorry for the capitols
Core Dimensions: 20 3/4" high x 19 1/4" wide (2-Row Core with 1" Tubes). Overall Dimensions: 26 3/4" High (Including Cap) x 23" Wide. Upper inlet: 1 1/2" located on Center. Lower outlet: 1 3/4" located on Passenger Side. Trans/Heater: Yes. BRACKET Mount System. OEM style brass petcock. drain. Billet style fill neck construction NOT STAMPED.
so beware when you buy, im so bummed out. t
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | would it fit if you relocated the mounting flanges on the radiator? I purchased a radiator from U.S. Radiator and when it arrived the top tank hit the top of the radiator mount. The mounting flanges were welded in the wrong location. ...pic... ...pic... U.S. Radiator, UPS picked up the wrong radiator and sent me out the correct one in a few days. No additional cost to me. I give that company high marks for the way the corrected the problem. | | | | | Joined: Jul 2012 Posts: 3 New Guy | | New Guy Joined: Jul 2012 Posts: 3 | exact same thing happened with my new radiator. I haven't decided what to do yet. probably just shem it out until I come up with a better plan. | | |
