| | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2003 Posts: 94 | Greetings All,
Has anyone had any experience with the water pump adapter plate for the later 235 engines?
Does it look "cheesy" or can one not tell the difference from the original 216 or early 235 pressure engines?
Have there been any problems like cracking or leaking or whatever?
So far I've only seen them at Carter's. Are there any other sources?
Any input is appreciated! Thanks! | | |
