1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Anyone put a push button starter in your 47-53 truck? Where did you put it? I am thinking the throttle cable hole since I don't have that cable.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that'd work, but in an area where auto theft might be common, maybe under the lip of the dash would be helpful .... along with a battery disconnect kill switch .... and a wheel lock  Bill | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | The stomp starter is a good anti-theft device, but here's a sneaky one somebody mentioned on the forum some time ago. The starter button was hidden behind a fake cigarette lighter, and cranked the engine when the lighter was pushed in with the ignition switch turned on. As an added anti-theft option, it would be easy to pocket the "lighter" when the truck is parked. Whomever thought that one up deserves a "well done"! Jerry
| | | | | Joined: Mar 2010 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 92 | My Dad installed a push button starter in my 49 big bolt (a long time ago) and he installed it on the left hand side. That way you can work the choke while you are cranking the engine. Of course that was before anyone worried about theft. Hope it helps.
1949 Chevy 4400 216
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Nash had a starter button mounted beside the clutch pedal, with a small tab attached to the underside of the pedal to depress the button when the clutch was pushed all the way to the floor. The 1950's Buick straight 8's were the slick ones- - - -a switch in the carburetor cranked the engine when the driver stepped on the gas pedal, then the switch was disabled by manifold vacuum once the engine started. Jerry
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | but here's a sneaky one somebody mentioned on the forum some time ago. The starter button was hidden behind a fake cigarette lighter, and cranked the engine when the lighter was pushed in with the ignition switch turned on. As an added anti-theft option, it would be easy to pocket the "lighter" when the truck is parked. Whomever thought that one up deserves a "well done"! Jerry Hmmmm, just may have to try this one!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Jul 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 25 | IM liking the cig lighter with a small pushbutton disconnect as wel, Picked one up in cedar rapids swapmeet this morning( under a blanket of rain) but that's ok! | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Some time ago, I drew up a circuit diagram for an anti-theft device that requires the driver to push a hidden button to energize a magnetic-hold circuit to complete the ignition circuit from the key swich to the coil. Anytime the key is turned off, the system resets itself to the "won't start" default position. It involves using two of the small square Bosch relays and a momentary-contact push button. Even if a thief manages to bypass the ignition switch or steals the keys, the engine won't start without pushing the hidden button. Jerry
| | | | | Joined: Sep 2011 Posts: 82 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 82 | I have mine set up with a kill switch to the distributor. It's a push button and the starter will crank over but it'll be no go till that switch is pushed. I also have a momentary switch acting as an on/off switch for my electric fuel pump. | | |
