| | | Forums66 Topics128,078 Posts1,055,936 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Hi All, How do you remove the front leaf springs from the saddle of my 51 Chevy COE. Am I suppose to drive the pin out of the saddle behind the bumper or will it come out by separating the leaf springs via u bolts? Thanks chris | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Saddle? can you show us a picture? | | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | I figured it out. Unbolt the bolt and the leaf springs drops out. I will eventually figure out how to post pics. I do not have one of the free services as of yet unless there is another way. I will see the axle shop tomorrow about joining my modern day 22.5 hubs to the original axle. Will let you know the results with part numbers and so forth if it works thanks' Chris | | |
