3 members (FishinToms53, Hotrod Lincoln, 1 invisible), 101 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
#887450 10/06/2012 9:13 PM
THe popping is it a bad valve or some other misterious factor of the grand poba????
Parisenne #887542 10/07/2012 10:07 AM
Popping like an engine mis-fire? Check your timing and valve adjustment. Think it's worse than that. Do a compression check.
Drew
Parisenne #887548 10/07/2012 10:17 AM
H Online: Content
Is the noise from the intake or the exhaust? Either way, it's probably caused by a sticky or burned valve. Check and correct the valve adjustment, then do a compression test. If one or more cylinders checks low, do a leakdown test where air pressure in applied through a spark plug hole with the crankshaft locked, and listen for a leak at the carburetor, tailpipe, and oil filler to see where the pressure is escaping. You're probably headed for a valve job to solve the problem.
Add cylinder head gasket blown between 2 cylinders to the list.
BC
1960 C60 pasture art
