| | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | This is a 4 speed transmission from a 1940 3/4 ton I think. It had a long bed. Is the shaft on the back of the tranny an open drive line? It has a torque tube, but I don't know how to identify this drive line. Thanks, Dan http://img.photobucket.com/albums/v617/daniel1060/transmission001.jpg
Trombones Totem Poles And Old Trucks!
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is how the 3/4 Ton driveline is designed. There is a short torque tube and then a universal for the open drive. What else did you want to know? | | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | Just wanted to confirm this was a 3/4 ton. Thanks!!
