1 members (baldeagle), 100 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,424
#88713 10/22/2003 5:20 PM
52' 3100 with 235
12 volt
It has 'never' missed a beat until the other day. It won't start. Here's the symtoms:
Cranks like a racehorse
But no spark
Guage cluster dead for fuel and charging
No headlights, parking nor breaklights
And yes, I do have the key on.
Suspicion...the ignition switch. How best to test?
Any other pathways to check?
Thank You ahead of time.
jeff
#88714 10/22/2003 6:28 PM
A '52 with a 235 running 12-volts is not original. That means the wiring may have been modified, and that makes it hard to know how it is setup...
Some of the things you are having trouble with do not normally go through the ignition switch, so it may not be the problem.
Since the starter functions you can assume the battery and battery cables are good. The problem is either the chassis ground (not likely) or the hot wire between the battery and everything else.
Check the number 10 or 12 wire running from the starter or charging circuit toward the fuses and dash. That is where I'd expect the problem to be.
#88715 10/22/2003 7:48 PM
seems like you do have a strange one,don't know about the lights and stuff but I for sure would check the coil,, points, etc dont give up, someone will come aboard to help you fix this thing,, good luck,,,,,Fred
Redryder pix
My Hotrod
#88716 10/22/2003 9:29 PM
Sounds like your electrical system is dead past your starter. Do you have the "foot stomp" starter? If so, OldSub probably nailed it...you have a wiring problem between your starter and the rest of the electrical circuit. Your ammeter may be "open" too. I don't have the stock wiring but I recall the ammeter was in series with everthing else. You can test the ammeter theory by installing a jumper wire. If you have a push button starter, then obviously you have power to that switch. Where does it get it's supply from?
#88717 10/24/2003 2:13 AM
The original wiring runs a main feed from the starter battery post, up to the headlight switch. There is a circuit breaker in the headlight switch that protects everything else in the truck, as you describe. The horn is an exception. Therefore a blown headlight switch circiut breaker will give you these symptoms.
1951 1 Ton Completed
