0 members (),
95
0
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | The speedometer on my 56 half-ton/ 3-spd is intermittent. the plastic gear in the transmission tail housing is very worn. the truck has a 3.90 axle. what is the proper color/tooth count for the gear i need? the one i took out has 22 teeth, but i see there are many different ones available. thx! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd just match what was there, most likely it's original? .... also you might want to check if the speedo head doesn't need cleaning and the cable is good, those trans gears get worn for a reason
Bill | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | thx - the speedo has been rebuilt and the cable is new, this plastic gear is the last link in the system. yeah - i can just match up what was there in the absence of a more definitive answer. the reason i am asking is a got a free 56 engine & trans from a bolter a while back and the gear in that one has 19 teeth ??? | | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | Most of the 55-57 truck 3 speed transmissions I have worked on used a metal driven gear. I think they have 19 teeth. OD's and pass cars used a plastic gear. The metal gear is considerably smaller than the plastic gears. You may be tearing up the plastic gear because it is the wrong application. I have a metal gear I could donate to the cause if it will help. Fred
