| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 18 New Guy | | New Guy Joined: May 2011 Posts: 18 | 51 Chev. 216- Shifter box been giving me a fit..hangs up. Took some parts out of 54 shifter box to replace some of the original parts. (One linkage arm on the 51 is longer than the 54, so reused the 51 arm.)Put back together now any tricks I should know about positioning the dog ears, etc. in the shifter linkage box? Actual linkage to transmission is in same position as it was when shifter box was removed. Any help suggestions, appreciated! Tex Chev. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | see the shop manual starting bottom of this page, and Fig.2 .... the forks need to be straight up and in line when in neutral, and the forks and pawl shouldn't be too worn at the tips Bill | | | | | Joined: May 2011 Posts: 18 New Guy | | New Guy Joined: May 2011 Posts: 18 | Bill, many thanks! Regards,
