1 members (Otto Skorzeny), 145 guests, and 0 robots.
Topics128,163
Posts1,056,921
Members48,458
Anyone have pic's of their 700r4 swap into their truck or burb with an inliner? I robbed the factory 5.7 bracket from a wrecking yard motor and before I fab it up, thought I would ask to see what others have come up with? Starting the swap behind the 250ci and into a 1969 c10 3:73. Running a Lokar under floor tall single bend shifter.
I don't have any pics, but be sure and build in plenty of adjustment capability. The 700R4's are terribly critical on throttle pressure adjustment. Plenty of transmissions have destroyed themselves over minor TV pressure errors.
Read this, http://www.tvmadeez.com/about.php
Also this,http://www.tvmadeez.com/index.php
Hotrod lincoln is correct ive been through this before with one of my other trucks. The TV cable is the most critical part of a 700R4, that is what makes it tick.
Bowtie overdrives makes & sells the TV made easy kits to properly adapt most carbs & fuel injection setups to a 700r4.
They also have tech support that will tell you how the transmission should be shifting.
