2 members (Maybellene, Gazz), 103 guests, and 4 robots.
Topics128,096
Posts1,056,482
Members48,444
#886134 10/01/2012 2:09 PM
The steering mast on ol' Bessie seems to have come loose. The wheel is still securely attached as is the column and things still seem to be good at the steering box. I can however move the wheel side to side and up and down within the column so I'm guessing the mast bearing has come apart?
Sound right?
Thanks!
yes, you need a new bearing
Agreed. You should also check the spring the goes under the steering wheel, it may be broken or missing. Without the spring, there's no preload on the bearing, which will allow the steering shaft to move in the housing.
Bill Burmeister
Spring? I'll have to look it up when I have a sec. I wasn't aware there was a spring. It all started with a clunk while maneuvering into a spot at the local big box hardware store. I wonder if that spring didn't just break or pop loose?
[edit]
Hmm. I'm not finding any mention of a spring in the manual or on any of the usual vendors websites.
the 'clunk' was the balls breaking out of a dry bearing
See Figure 2. I don't beleive that spring is available reproduction. Mine was missing from my '55, I just matched the diameter to the bearing and cut one down from the local Lowes store.
Bill Burmeister
Thanks fo the link LONGBOX55. I must have been skipping over that page. I'll have to pull it all apart and look.
