7 members (tclederman, RoadsScholar, DadsFirstPickup, baldeagle, MickeyP, Stovebolt48, 1 invisible),
198
Mod | | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Guys I have some older chrome slotted wheels that have several rust spots etc. I was thinking on painting them but wanted to know if the paint will stick to chrome. If so what type of prep is needed ?Thanks
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | from experience, paint doesn't stick very well to chrome. but you con make them look good for a few years(1-2) if you sandblast the rust areas and sandpaper the chromeand use a good paint(not rattlecan rustolium). other than that -no.
daren | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Paint won't stick well to chrome IF it isn't prepped right. Chrome is smooth and shiny. Paint won't stick to smooth and shiny. Make sure the wheels are clean and grease/oil free. Rough up every square MM of surface where you plan to paint. That will get rid of the smooth and shiny. Prime and paint. I personally prefer powder coat over paint. It's much more durable.
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | I'd reccomend sandblasting with a pretty coarse media, then using a self-etching primer before painting. The chrome needs to be roughed up enough for the primer to get a good bond before the paint will stay put. Jerry
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | maybe you could remove the chrome layer? i don't know if that is possible though
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | Just sandblast the complete wheel & be done with it. As long as its blasted , primer will stick. | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Thanks guys for all the good responses. I have a sandblaster so will go that route with self etching primer.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Be careful that you use very low intensity when blasting. You don't want to cause warpage to the wheel or damage it in any other way. This is a case where even if I had the equipment myself I would consult a pro before attempting anything. | | |
