9 members (55shaker, 1955 1 Series, BC59, 3800GUY, RaNfLaS, tclederman, Otto Skorzeny, wilbur53, FAST55), 156 guests, and 0 robots.
Topics128,104
Posts1,056,201
Members48,436
#886116 10/01/2012 1:17 PM
Guys I have some older chrome slotted wheels that have several rust spots etc. I was thinking on painting them but wanted to know if the paint will stick to chrome. If so what type of prep is needed ?Thanks
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
from experience, paint doesn't stick very well to chrome. but you con make them look good for a few years(1-2) if you sandblast the rust areas and sandpaper the chromeand use a good paint(not rattlecan rustolium). other than that -no.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
http://www.doublegcustoms.com
Ex Hall Monitor
Ex Hall Monitor
Paint won't stick well to chrome IF it isn't prepped right. Chrome is smooth and shiny. Paint won't stick to smooth and shiny. Make sure the wheels are clean and grease/oil free. Rough up every square MM of surface where you plan to paint. That will get rid of the smooth and shiny. Prime and paint. I personally prefer powder coat over paint. It's much more durable.
I'd reccomend sandblasting with a pretty coarse media, then using a self-etching primer before painting. The chrome needs to be roughed up enough for the primer to get a good bond before the paint will stay put.
maybe you could remove the chrome layer? i don't know if that is possible though
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Just sandblast the complete wheel & be done with it. As long as its blasted , primer will stick.
Thanks guys for all the good responses. I have a sandblaster so will go that route with self etching primer.
Be careful that you use very low intensity when blasting. You don't want to cause warpage to the wheel or damage it in any other way. This is a case where even if I had the equipment myself I would consult a pro before attempting anything.
My 46 GMC on Photobucket
