7 members (DaveV, Wayne67vert, Bullriders, treegrower, Phak1, Bill Marlow, 1 invisible),
42
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,005 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 52 | I am in the process of completely removing the bed from my 1965 C10 Fleetside truck. I have removed all of the wood and I am now trying to disassemble the bed sides from the rear crossmember under the tailgate. Are the bed sides just bolted to the rear crossmemeber are is it welded together somehow? Any advice on how to disasseble these parts would be appreciated. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | There are two stich-welds on each end of the rear main cross sill...one on the top of the sill and one on the front face. With a cutting wheel in a die-grinder, they can be scored and the bed sides can be removed from the rear main cross sill.
There are also four shoulder bolts on each end of the rear main cross sill, securing it to the bed sides. | | | | | Joined: Dec 2009 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 52 | Thanks Tony. One other question. Is there any way to remove the tailgate without removing the bed sides? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I replied to your question, via a PM. | | |
