5 members (Shade Baby, Bill Hanlon, Gdads51, 2-Ton, Jeff Ogden), 121 guests, and 4 robots.
Topics128,151
Posts1,057,005
Members48,460
#885729 09/30/2012 7:45 AM
My truck is a 1956 3100 step side with a big back window. I live in Las Vegas so I am not worried about snow and salt, just the heat. I will be picking up my 235 block back from the machine shop this week. The truck colors I have selected is preformance yellow and black with chrome lights, grill, and bumpers. I wish to paint the block, head, water pump, valve cover, side cover, and oil pan preformance yellow, however I have a few questions.
How many cans of paint is needed?
What temperature should the paint be able to withstand?
Any recommendations or precautions should I be aware of?
I will paint the motor preformance yellow and the fan blade, starter & generator black. What would be a nice color for the clutch housing and 4 spd transmission?
Lastly I found this paint on the web it matches the color I wish to paint the body, would this be good for the motor? VHT 550°F (288°C) Engine Enamels™ are available in a wide range of colors, including exact match factory colors. All colors have excellent durability and superior heat and chemical resistance. They are specially formulated to withstand corrosion, rust, salt spray, chemicals and additives of today’s gasoline blends and degreasers. VHT 550°F (288°C) Engine Enamels™ are a unique blend of urethane and ceramic resins, which produce a tough and long-lasting finish for engines, engine accessories or wherever a tough durable heat or chemical resistant finish is needed.
If anyone has a recommendation of paint type or manufacturer that produces it in a spray can I would love to hear it. I do not want to cheap out for a few dollars. Thanks
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
Sorry folks I think i deleted my question by accident how many cans of spray paint should expect to paint a 235 motor?
any recommendations of manufacturers, engine temps or other concerns that I should be aware of?
thanks
56 Chevy 3100
so far on my 235 i have painted the head, which used only one can of paint, and another can to paint the manifolds,so i'm guessing it will take 3 to 4 cans of paint to do the block, not counting the valve cover, oil pan, manifolds, etc. hope this helps,
Indy wink
P.S. i would buy extra just in case something happens. for instance, i had just painted my manifolds and they looked beautiful. but they then fell off my table and got grass all over the wet paint and so i had to repaint. very frustrating.
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Thanks for the info. Do you or anyone have recommendations of which type of paint or manufacturer? The color I have chosen is a performance yellow.
56 Chevy 3100
Your first post is not lost, it can be viewed by clicking Quick quote.
Hopefully a moderator will be along to fix your post.
I used 3 cans of duplicolor engine paint. It's held up well for 2 years.
No special baking necessary. Just make sure everything is clean.
The exhaust manifold I used eastwoods exhaust paint. I believe it was the cast iron finish. It's also held up pretty good.
Intake I used the same engine rattle can.
Good luck
Red dot, center of chest ...
This is the original post by TinyJaime.
What temperatures should the paint be able to withstand?
I will paint the motor preformance yellow and the fan blade, starter, & generator black. What would be a nice color for the clutch housing and 4 spd transmission?
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
This is the original post by Tiny Jaime.
Paul Schmehl CI 6
geek@stovebolt.com
This is Tiny Jaime's original post.
Paul Schmehl CI 6
geek@stovebolt.com
Testing. Moderators, please do not delete this topic. I'm working with the software company to figure out what's causing these blank posts.
Paul Schmehl CI 6
geek@stovebolt.com
56 Chevy 3100
Jaime - copying and pasting from another application is a problem that hasn't been sorted out, you likely started out using Word or some other Microsoft editor? using the quote button and then doing a copy/paste again doesn't change things - either write out your post directly here or wait and see if Paul can get this bug sorted out
When I originally created the post I did do a cut and paste from a product I found that I was trying to receive info from someone who may have used it. Ahhh I seemaybe that's what happened. Although the question was typed in the box here I did cut and paste product info. Ok thanks. I was curious and it the quick reply to see if the original post was there and it did show up then when I did not reply it disappeared again. Ok thanks for the info and its a learning thing for me sorry if I caused any trouble. This site really helps me in my 56 restoration.
56 Chevy 3100
Good luck
Are you referring to the engine in the u-tube video? If so can you tell us what color of duplicolor that is?
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
gray engine paint Dupli-Color Ford Gray #DE1611.
I think they call it new ford gray now, not sure if the color changed with the name change. I painted mine a few years ago.
It's not original looking missing the blueish hue some say was original.
But I was happy with the results for my driver.
