7 members (RoadsScholar, Hanks custodian, thekid1950, Peggy M, Hotrod Lincoln, dt235sd, Thomaslb), 193 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
#885744 09/30/2012 8:52 AM
Truck is at the body shop for paint and reassembly. When the doors were removed, the slide nuts broke off. I think they're called cage nuts. they sit behind the pillar and are used to align the door with a slotted hole and the nuts that slide when the door hinge is bolted into them..I can't find them anywhere in any catalogs..any advice is appreciated Please help..TIA
McMaster Carr online, toward the bottom of the page.....
http://www.mcmaster.com/#weld-nuts/=jilqvs
Thanks so much for that info, I need to find out the size of the bolts and get these things ordered asap....what a great forum !
