5 members (52Carl, 55shaker, 2-Ton, crenwelge, Gray_Ghost), 218 guests, and 2 robots.
Topics128,108
Posts1,056,237
Members48,437
Does anyone know of a rubber company other than Steele Rubber..that might have those twin window gaskets in upper rear door, either 36 Pannel or Suburban? Steele doesn't have them..thanks... searching. Bruce D.
1936 Chevy Suburban Carryall
1941 Chevy Woodie with Cantrell body
1936 Low Cab Chevy Pickup
1941 Spec Deluxe Chevy Coupe.
1953 Pontiac Catalina hardtop
More pix on Flickr
if Steele doesn't have it, nobody will, the 36 door/window configuration is a bit odd - you need to get the windows out and document the profile of the rubber and then ask Steele what they have similar - in fact if you can get one rubber out complete in good enough condition, they may be able to reproduce it for you - not cheap, but can't be choosy
