7 members (FrankenChevy, 3B, msmall, walter74, Stovebolt48, Shardean, 1 invisible),
63
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Does anyone know of a rubber company other than Steele Rubber..that might have those twin window gaskets in upper rear door, either 36 Pannel or Suburban? Steele doesn't have them..thanks... searching. Bruce D. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if Steele doesn't have it, nobody will, the 36 door/window configuration is a bit odd - you need to get the windows out and document the profile of the rubber and then ask Steele what they have similar - in fact if you can get one rubber out complete in good enough condition, they may be able to reproduce it for you - not cheap, but can't be choosy
Bill | | |
