0 members (), 89 guests, and 0 robots.
Topics128,049
Posts1,055,637
#88534 05/05/2002 6:42 PM
What are the advantages & disadvantages of changing from an generator to an alternator?
Does this conversion involve new brackets? Is so are there any recomentadtions for type?
What changes are required to harness or other electrical components (voltage regulator, lights, etc)
Forgot to mention engine:
1958 235.
I am also considering adding an electronic ignition system down the road.
The major advantage is that the alternator will charge at idle. Personally, I wouldn't make the change unless the generator or regulator were bad, or I had the engine our, or I had money burning a hole in my pocket. With the right alternator, you can use your existing brackets. Best thing to do is to take your generator to your local parts store. They should be able to find one that will only require a bushing on the aft end of the lower bolt.
Fred
52 3600
69 C-10
Contact Buffalo Enterprises
Buffalo
for both the alternator bracket and HEI to fit your 235.
Wiring changes are minimal. GM alternators have internal regulators so that's one less part to clutter the dash and go bad. Get a DA plug fom Patrick's or 5th Ave auto parts (See the Links on this site). I had constant problems with dead batteries when using generators, never since changing to an alternator. Any problems and you can pick up a rebuilt unit anywhere. Be sure to use the smaller pulley as an alternator needs to spin faster to keep up a charge at idle.
I have used an 12 volt generator on my 50 for 38,000 miles now. Electric wipers, halogen lights, 40 watt stereo and never had a dead battery. I don't do much city driving though and if I spent most of my time sitting in traffic I might consider an alternator. I like the generator for the same reason I run dual rochesters instead of a 4 barrel, I like the nostalgic look.
Grant
1950 Chevy 3100
1952 GMC 150 (In Pieces)
1968 Chevy K20
1966 Shovelhead
1978 BMW 100S
If you will send me your snail mail address I will send you a copy of the famed "Alternator Gazette" which explains the differences and gives you the background to help you decide which is best for your application. I also have the alternators brackets pulleys etc if you decide to go that route. If you have further questions after that you can give me a call. Thanks Randy grin grin grin
