4 members (DoubleB, greenie-reddy, 41appletruck, Oswald), 85 guests, and 1 robot.
Topics128,091
Posts1,056,038
Members48,433
#884145 09/22/2012 6:24 PM
I am putting in an 81 pontiac firebird rear. I needed to pull the axles, the pin that holds the pinion in is attachedto a set screw which i had to drill out. I needed to drill the hole and rethread so now it is a slightly larger size. How do i find a new set screw pin combo?
Search on the net for Randys ring and pinion in everett washington.
