6 members (TexasA&M48Truck, Gray_Ghost, Bill Hanlon, Shade Baby, Nhluvstruck, 1 invisible), 200 guests, and 2 robots.
Topics128,087
Posts1,055,985
Members48,430
#884145 09/22/2012 6:24 PM
I am putting in an 81 pontiac firebird rear. I needed to pull the axles, the pin that holds the pinion in is attachedto a set screw which i had to drill out. I needed to drill the hole and rethread so now it is a slightly larger size. How do i find a new set screw pin combo?
Search on the net for Randys ring and pinion in everett washington.
