6 members (Shade Baby, Patharr, Ponchogl, TrknGMC, Bill Hanlon, 1 invisible), 98 guests, and 0 robots.
Topics128,119
Posts1,056,311
Members48,439
Hi everyone,
I have a 69 C-10 and I get no temperature gauge reading. Do I only have to test the sender and the gauge?
How does one test a temp sender and temp gauge?
Or should I just buy new ones?
Any help would be appreciated.
69 C10 LWB 250 L-6/3spd
79 C30 Crew Cab Dually 454 V-8/TH-400
"Takes more than a coat of paint to make it at Thunder Road!"
To test for a bad sender on my 70 chevy I just removed the sender wire from the sender and grounded the wire to the motor with the key in the on position. The gauge went to hot so I knew it was a bad sender. If the guage still didn't read it would have either been a bad gauge or a bad wire from the gauge to the sender since the gauge had power to it.
Joe
To test the sender attach an ohm meter to the terminal and the base, stick the bulb end in a beercan full of water, then heat the beercan to boiling with a propane torch. There should be resistance when cold and little to none when hot. If there is no continuity the sender is bad.
Don't forget to check the grounds. The sender has to be grounded to the block so clean out the rust in the threads and don't use any teflon or pipe dope. The gauge has to be well grounded too.
Paint & Body Shop moderator
Thanx Guys, ends up the wire was bad.
The sender and guage tested fine.
I liked the fact that you have to drink a beer before testing the sender.
