| | | Forums66 Topics128,077 Posts1,056,016 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88503 08/29/2004 9:18 AM | Joined: Aug 2004 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 52 | Just bought a '68 Chev P/U, and after changing the ignition switch, the ammeter and temp gauge aren't registering anything. Any suggestions?
Paul
1946 GMC 1/2 ton 1967 Chevy 1/2 ton
This old truck sure looks neat, but where are the heated seat controls?!?
#88504 08/29/2004 2:21 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Ammeter problem is probably the gauge, Temp is usually the sending unit. To check the temp, disconnect the wire from the sending unit and ground it. Should peg the gauge, iirc. You can buy a sender at your local auto parts store. The gauges you can get from one of the on-line vendors in the links section.
Fred 52 3600 69 C-10
