5 members (78buckshot, KEVINSKI, GRNHydra, Gray_Ghost, Guitplayer), 189 guests, and 7 robots.
Topics128,078
Posts1,056,039
Members48,433
#88503 08/29/2004 9:18 AM
Just bought a '68 Chev P/U, and after changing the ignition switch, the ammeter and temp gauge aren't registering anything. Any suggestions?
Paul
1946 GMC 1/2 ton
1967 Chevy 1/2 ton
This old truck sure looks neat, but where are the heated seat controls?!?
#88504 08/29/2004 2:21 PM
Ammeter problem is probably the gauge, Temp is usually the sending unit. To check the temp, disconnect the wire from the sending unit and ground it. Should peg the gauge, iirc. You can buy a sender at your local auto parts store. The gauges you can get from one of the on-line vendors in the links section.
Fred
52 3600
69 C-10
