8 members (David Bush, kades51, BC59, MikeE, Bucker, MickeyP, Rexville48, dt235sd),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | As promised here's the results of the Zenith carb swap on my G506 with a 261. Over all the truck runs much better through out the rev range and the truck starts by just barely stepping on the starter. My seat of the pants dyno tells me it is about 30% better now at pulling steeper grades in high gear. Again this is a very heavy truck with for the time being over sized tires, 900-20's When it should have 7.50 - 20's that are about 4" shorter and will give my original gearing back. I would think in a half ton truck running closer to sea level the improvement would be even more noticable. Bottom line here for the $ spent I'm happy with this latest upgrade!
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | The Zeniths are better carbs. Glad it's running well for you. | | |
