3 members (Hotrod Lincoln, baldeagle, 1 invisible), 67 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,420
#884843 09/26/2012 9:27 AM
Truck is a 49 3100. Engine is a 235. I'm hearing a subtle tapping when cold so thought I'd check valve clearances. But discovered that I don't know if I have hydraulic lifters or not. Here's what I found on the engine:
Flat plate behind distributor: F410A
On block above starter: CON40 AD 57 (not sure if it's an A or a dimple).
On cyl head above intake manifold: 3836848 GM10
On block below distributor: 383004
On cyl head above plug #3: B50 848/850
Hopefully this provides enough info to ID.
Appreciate any help,
Mike
Srhdad #884871 09/26/2012 11:16 AM
I can't match the block number and I guess nobody else can either. Are you sure it's correct? Or: Pull the side lifter cover off and check that way. You'll know for sure than.
Drew
DrewP #884902 09/26/2012 1:39 PM
How will I know? What should I look for beneath the side cover?
Srhdad #884906 09/26/2012 1:47 PM
Most likely the casting number is 3837004 which is a 1955/57 235 engine
The 848 head came on the 1956-1962 engine.
GMONIZ #884907 09/26/2012 1:50 PM
The side cover removed, would allow you to see the lifters.
It's definitely 383 004 (nothing in between). Sorry for my inexperience, but...with the side cover off, how would the lifters of a hydraulic system look different from push-rod? Will I simply see the pushrods?
Srhdad #884919 09/26/2012 2:42 PM
the 55 shop manual is here - close enough to the probable year, should tell you what to look for, but it's unlikely it's got hydraulic lifters
