1 members (SlimSix),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | What is the correct steering box lubricant? Have rebuilt and adjusted the steering box on my 55 series II model 3200 and now I need to refill the lubricant. Many Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | John Deere Corn Head Grease
It is a self-leveling grease.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | What he said. Get 2 tubes and squirt it in with a cake decorating bag until full. The urban John Deere lawnmower dealer may not have it on hand but should be able to have some transferred from an agricultural location within a couple days.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | IMHO, Corn Head grease is an acceptable substitute for the "correct" grease, whatever correct may be. "Steering gear lubricant" is the correct lubricant, but what is that? The main goal is to use a lubricant that is self leveling, not too thick and not too thin, but just right  . I mixed my own grease by using a combination of 120 weight gear lubricant and bearing grease. Mixed it together until I got the consistency I wanted. For me, that was easier than find Corn Head grease and I can replicate it at any time if top-off is ever needed. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Although John Deere Corn Head Grease may be a good choice,(I have not used it or taken a box apart that has) especially for a leaking box, there is nothing wrong with using 90w on a box with good seals. I have rebuilt a lot of steering boxes and what ever you use make sure it flows. Using grease is not much better than having nothing at all in it.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I think if you dig into this you will find that cornhead grease is the correct lubricant for a steering box. Steering gear lube is a self leveling grease, as is cornhead grease. I'm sure any number of combinations will work so whatever give a peace of mind is the stuff to put in.
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Is there anyway to get the existing grease out of the box without removing it from the truck and disassembly?
Kurt | | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | According to info on corn head grease tube there are sealing properties which may help a leaky seal. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I installed a new seal when I rebuilt my box and found that 90 wt would weep onto the spring/frame but switching to cornhead grease stopped it completly. If it's got gear oil in it removing the lowermost cover bolt will allow most of it to drain out but cleaning out grease may require disassembly.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | If oil drain at bottom bolt. If grease, add 90 weight gear oil to dilute grease and make it flow… | | |
