3 members (2-Ton, NJC, 1 invisible),
95
0
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88482 08/04/2003 12:47 PM | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | I re-assembling my '51 3100, and converting to 12v alternator. New wiring harness has two wires with push on connectors for the GM alternator that are designated for alternator terminals L1 and L2. Can anyone tell me how to determine which of the alternator push on connections is L1? They are not labeled on the alt and I'd hate to lose the alternator's factory packed smoke first thing. Thanks! | | |
#88483 08/04/2003 1:28 PM | Joined: Dec 2000 Posts: 25 Member | | Member Joined: Dec 2000 Posts: 25 | If you will hold your alternator so that you are looking at the back L1 will be to the left, L2 will be to the right. The original plugin had the small cut out for the lock to lock in place. Again, the L1 will be to the left, L2 to the right.
1950 3100 5-window
#88484 08/04/2003 1:34 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Lionel: you are correctamundo!!popcorn The Truth is Out There (good luck) | | |
#88485 08/04/2003 1:45 PM | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | Thanks much, fellas..that's one less problem to have when i finally try to start everything up. | | |
