10 members (5 Window 9434, cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible), 94 guests, and 3 robots.
Topics128,062
Posts1,055,847
Members48,428
#884816 09/26/2012 6:52 AM
What is the correct steering box lubricant? Have rebuilt and adjusted the steering box on my 55 series II model 3200 and now I need to refill the lubricant.
Many Thanks
John Deere Corn Head Grease
It is a self-leveling grease.
What he said. Get 2 tubes and squirt it in with a cake decorating bag until full. The urban John Deere lawnmower dealer may not have it on hand but should be able to have some transferred from an agricultural location within a couple days.
You Tube
IMHO, Corn Head grease is an acceptable substitute for the "correct" grease, whatever correct may be. "Steering gear lubricant" is the correct lubricant, but what is that? The main goal is to use a lubricant that is self leveling, not too thick and not too thin, but just right smile.
I mixed my own grease by using a combination of 120 weight gear lubricant and bearing grease. Mixed it together until I got the consistency I wanted. For me, that was easier than find Corn Head grease and I can replicate it at any time if top-off is ever needed.
Although John Deere Corn Head Grease may be a good choice,(I have not used it or taken a box apart that has) especially for a leaking box, there is nothing wrong with using 90w on a box with good seals.
I have rebuilt a lot of steering boxes and what ever you use make sure it flows. Using grease is not much better than having nothing at all in it.
My Blog
I think if you dig into this you will find that cornhead grease is the correct lubricant for a steering box. Steering gear lube is a self leveling grease, as is cornhead grease. I'm sure any number of combinations will work so whatever give a peace of mind is the stuff to put in.
Is there anyway to get the existing grease out of the box without removing it from the truck and disassembly?
Kurt
According to info on corn head grease tube there are sealing properties which may help a leaky seal.
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
I installed a new seal when I rebuilt my box and found that 90 wt would weep onto the spring/frame but switching to cornhead grease stopped it completly. If it's got gear oil in it removing the lowermost cover bolt will allow most of it to drain out but cleaning out grease may require disassembly.
You Tube
If oil drain at bottom bolt. If grease, add 90 weight gear oil to dilute grease and make it flow…
