6 members (cmayna, KEVINSKI, jmoore, MTD91, fonz8261, 1 invisible), 374 guests, and 2 robots.
Topics128,268
Posts1,058,395
Members48,485
#884698 09/25/2012 7:24 PM
I
I Offline
1949 One ton Dually
Well my lug nuts loosened up on the rear axle and I snapped one off. I am trying to find a replacement for it. I popped the good one next to it out and took to local parts store and the closest thing they had the knurl is to long and the brake drum won't go on. Anybody every done this job and have a part number by chance?
Chevs of the 40's didn't have one and waiting for a call back from Jim Carter. Just trying to cover all my bases on finding parts so I came here also.
My new 1949 Chevy One Ton Dump Truck. Still have it but parked, needs a new motor.
1953 2 ton parts truck Long Gone
1957 GMC LCF On 75 Cadillac Eldorado Frame
Updated Feb 2021
3B Offline
Hy IBenDcars, Napa lists Balkamp p/n BK641354, o.a.l. 1 11/16", knurl diameter .56", length of shoulder 19/32", 1/2" X 20 t.p.i., hope that helps.
I was able to get them for the rear of my 1951 1 Ton from LMC. It took three tries for them to ship the right stuff but I got them in the end.
1951 1 Ton Completed
I
I Offline
I am quessing o.a.l. is overall length
That says it is 1 11/16" and mine is 2 1/4" overall. I don't think I can go over half an inch shorter but will look at it
Updated Feb 2021
I
I Offline
I just called LMC and as soon as I said "one ton dually" the gal I was talking to was absolutely no more help.
Jim Carter called back and they have nothing either.
Updated Feb 2021
If you go to the LMC site, enter your year and make of truck and for the search "30 1026" it will bring up rear studs for a 3/4 Ton. I believe they fit the 1 Ton single but I don't know about a dually. Here is the catalog page LMC Catalog
If you have a NAPA in your area, I would go there first. They've came up with all kinds of stuff for my truck. If all else fails, could you grind off a little of the shoulder on the one you found at your local store so that the drum would clear?
I
I Offline
That's exactly what I did today. I chucked the studs in a drill and put them to the grinder.
The part # I used is Dorman 610-730. They are a little longer than stock but not much.
Updated Feb 2021
What a deal. A little ingenuity goes a long way.
Moderated by  Dusty53
