| | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Will 9r 22.5 s fit under the 50 s coe without rubbing, I located some with a disk brake set up and axle from a magnum mid ninties motorhome diesel pusher chassis. Speaking of the diesel pusher, can the axle be flipped to use on our coes? Thanks much Chris | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | They are 38" tall, should fit. What model truck do you have with what size tires now? | | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Grigg, Thanks for the response. I have the chevy 51 coe. I have the original split rings. Heading your advice I do not intend to use them. I assume if I put theses on the truck, height will increse. by how many inches? I do not want to go any higher. I will not be able to get it in the garage. Thanks Chris | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Do the math, 38" - (your tire size) all / 2
If you're swapping axles as well then it can be more complicated to figure depending on springs and difference in spring pad to wheel center line of the two axles.
If your wheels are RH5* then great idea to swap, if any other multi-piece wheel then likely you can use them if in good shape.
Grigg | | |
