| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Looking for suggestions and photo's of a interior rear view mirror in a 1946 pickup. Thanks, Harold
Harold Is a restoration ever finished? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I used an original mirror from a 47-53 truck on my '46. It works great attached to the panel above the windshield, and isn't so big that it blocks your front visibility. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I used one from a BMW 735. Attached to the windshield divider bar. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Thanks guys,  Could you post a picture of the installation? Britcon, Did you drill an oversize hole & re-thread the divider bar or did the BMW mirror stem fit? Harold
Harold Is a restoration ever finished? | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Harold....BMW arm had a ball in socket type fitting on the end which I removed. I drilled a hole in the end of the arm, and used a long stainless steel cap screw which threaded into the holes in the divider bar. Mirror was from an older ( mid 90's ) 735 so it didn't have all the bells and whistles the new ones have ( compass / auto dimming ) | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I won't be able to snap a picture until the weekend, but I'll try to post one. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Some pics start Here Maybe help. Have fun and good luck Dan | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Dan, Thanks. This gives me a reference point. How is the visibility from the mirror mounted that high in the cab? Harold
Harold Is a restoration ever finished? | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | I mounted mine under the header panel, centered it and drilled the header panel slightly larger. Picture 63 in build link shows it. It's a small mirror I picked up off of ebay. | | |
